DMA FIFO FPGA in CVI or LabVIEW
FPGA Target FIFO is configured for 8197 elements
                NiFpga_MergeStatus(&iFpgaStatus, NiFpga_Open(FPGABitFileName,
                                                             NiFpga_RseriesRIO_Signature,
                                                             Address,
                                                             0,
                                                             &hSession));
                NiFpga_MergeStatus(&iFpgaStatus,NiFpga_ConfigureFifo(hSession,
                                        NiFpga_RseriesRIO_HostToTargetFifoU8_DMAFIFO,
                                        3000000));
NiFpga_WriteFifoU8(hSession,NiFpga_RseriesRIO_HostToTargetFifoU8_DMAFIFO,
  uArray,
  20000,NiFpga_InfiniteTimeout,
  &uEmptyElementsRemaining);
uEmptyElementsRemaining  is 2980000   <----------After above call
  uArray,
               uEmptyElementsRemaining  is 2968197   <----------After above call
[Was expecting 2960000 elements remaining in DMA FIFO after second call]
When the same steps are executed on LABVIEW [with labview equivalents of above functions], it produced different result. i.e. When executed with Labview [with same FPGA FIFO size and DMA fifo size] ,
uEmptyElementsRemaining  was 2980000 and 2960080 after first and second write method.
Also when Labview VI was run continuously, uEmptyElementsRemaining   was changing after the second write method but was correct [2980000] after first write method.
(2,561 Views)
Hi SchamWow,
Are you calling the NiFpga_StartFifo in the same order in your LabVIEW and CVI code?
NiFpga_StartFifo
NiFpga_Status NiFpga_StartFifo(NiFpga_Session session, uint32_t fifo)
Starts a FIFO.
Parameters
NameTypeDescription
session NiFpga_Session handle to a currently open session
fifo uint32_t the FIFO to start
(2,537 Views)
