Can I Write Data to a *.xlxsx File Without Screwing Up the Excel File Formatting?
I'd like to programatically add LabVIEW-generated data to a nicely-formatted *.xlsx file, one with all the right borders and column widths, etc.  But every time I try to add the LabVIEW data, the xlsx file formatting gets all screwed up and the file gets corrupted.  Is there a way around this?
Thanks!
- FB
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,832 Views)
How are you modifying it? Are you using the XML parser? However you are doing it you have to make sure you are paying close attention to the spec in the MSDN. I have never used it but the report generation toolkit might help a lot.
LabVIEW 2012
(3,830 Views)
Accepted by topic author diarmaede
It will probably be easier to use ActiveX to control Excel and modify the file that way if you have that option, instead of writing the XML directly.
(3,823 Views)
Absolutely! But even that is a pain. I don't know for sure but I would imagine that the report generation toolkit uses ActiveX under the hood.
LabVIEW 2012
(3,818 Views)
Yes, the Report Generation Toolkit uses ActiveX automation to build Excel and Word reports.
(3,810 Views)
FB,
I was able to find the following link on the NI website.  I think it addresses the issue you are describing using the Excel ActiveX interface.
AutoFit Columns and Rows in Excel Using LabVIEW: http://digital.ni.com/public.nsf/allkb/8697100BBFA68902862571D4006D893B?OpenDocument
Isaac S.
Isaac S.
(3,789 Views)
I'm slogging my way up the ActiveX learning curve.  It's challenging, but fun.
Forbes Black
(3,774 Views)
