Followed LabView toolkit for Arduino instructions but still not working
Hey everyone,
I'm an undergrad working on a research project and we are trying to use the Arduino UNO to get real time data from an experiment we are conducting. I have installed labview 2011, NI-VISA and Arduino 1.0.1 following the instructions for the setup. I loaded the firmware to the arduino and the send/receive lights on the arduino flashed when I ran the program, however, when I attempted to change the LED status from on to off (LED example) there was no response from the LED. I did not receive any communication errors so I'm not sure what is the problem. I checked the Measurements and Automation and it recognizes the board and I checked to make sure the  baud rates matched. Still no luck. Any ideas would be greatly appreciated.
(2,632 Views)
You'll probably have better luck getting help with this issue if you go to ni.com/arduino and click on the discussion tab. Most customers and NI employees who use work with the Arduino post on that discussion board. In addition, ni.com/arduino has a lot of useful information that you might find helpful.
Brice S.
www.ni.com/support
(2,608 Views)
