04-24-2015 10:44 AM
Hello everyone,
I need a DMA FIFO host to target FPGA between a PXI-8106 and a PXI-7852R, I am working under Labview 14.0.1
I need to know the available spaces before writing in the FIFO to avoid overflow, but I can't find a VI which can do this, the only way I know to get the available spaces in the FIFO is creating a invoke method <write>, but that means I have to write date before knowing the available spaces.
Then I tried a another VI, <FIFO.Acquire Write Region (Invoke Method)>, but I got a error:
L'erreur -63193 s'est produite à : Invoke Method: FIFO.Acquire Write Region in cerclefifo v10 invoke referencev2.vi
Raisons possibles :
NI-RIO: (Hex 0xFFFF0927) The requested feature is not supported.
I think that means my embedded controler is not supported by FIFO.Acquire Write Region (Invoke Method).
Do you hace some ideas how to solve this problem? Thanks a lot.
04-24-2015
10:57 AM
- last edited on
10-14-2025
08:44 AM
by
Content Cleaner
Hi Junli,
You can actually do a zero element write, which will return the number of empty elements in the DMA FIFO buffer. We document that here, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9SASA0&l=en-US, for the read case. I did a quick search and couldn't actually find a document that covers the write case, but I'll update if I do.
Sebastian
04-27-2015
02:27 AM
- last edited on
10-14-2025
08:44 AM
by
Content Cleaner
Hi, Sebastian
The link you posted isn't accessible now, can you check it please?
speleato a écrit :
Hi Junli,
You can actually do a zero element write, which will return the number of empty elements in the DMA FIFO buffer. We document that here, http://digital.ni.com/public.nsf/allkb/583DDFF1829F51C1862575AA007AC792, for the read case. I did a quick search and couldn't actually find a document that covers the write case, but I'll update if I do.
Sebastian
04-27-2015
05:00 AM
- last edited on
10-14-2025
08:45 AM
by
Content Cleaner
The error is due to the comma at the end
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
04-27-2015
08:38 AM
- last edited on
10-14-2025
08:45 AM
by
Content Cleaner
The new link you posted isn't any better...
04-27-2015 09:18 AM
Thanks, everyone, for a FIFO DMA Host to target, there are few examples, I will try to write a empty array in order to query the space avaible in the FIFO on the host side.
04-27-2015 09:21 AM
This is my VI on the Host.
I use a while loop to quiry the space avaible in the FIFO until at least half of the FIFO is empty, then I write date into the FIFO
04-27-2015 09:23 AM
04-27-2015 09:52 AM
Hey Junli,
That looks like the right idea, did this sovle your problem?
One thing I noticed is that the loop timer is outside of the polling while loop, so it's not actualy controlling the polling rate. I think you'll want to move it inside the loop or delete it if your intent is to run the polling loop as fast as possible.
Sebastian
