11-24-2020 04:17 AM
hi all,
I have a PXIe 1082 with 4 DMM cards 4081 and 1 analogue card 6361. I perform some measurements with the DMM cards.
The 4 DMM cards are synchronise owing to the PXI trigger line 0.
The sampling frequency is around 100Hz but this value depends of my card initialisation (aperture time, average, autozero,....).
I would like to synchronise the analogue card with the DMM. Do you have some suggestion?
Thanks for your idea
11-25-2020
04:49 AM
- last edited on
03-06-2025
02:10 PM
by
Content Cleaner
Hi diotspower,
There is no easy way to synchronize an USB and PXIe card as they don't share any buses.
You can use a timing card in your PXIe chassis to export the backplane trigger and wire it to the PFI input of you USB-6361.
Here is a link explaining how the timing card works: https://www.ni.com/en/support/documentation/supplemental/18/using-pxi-timing-and-triggering-function...
Clement
11-25-2020 04:54 AM
Hi Clement,
Thanks for your help.
My analogue card is not a usb version it's a PXIe card too. The DMMs and the 6361 share the same PXIe backplane.
Regards
