XY graph with missing dates
Hello community,
I'm struggling making an XY graph with some data missed. In this example, there isn't data from Nov 19th. I was wondering if there is an easier way to generate the correct graph instead that said in this post:
https://forums.ni.com/t5/LabVIEW/To-find-the-missing-date-in-a-month/m-p/507357#M241845
Thank you
(1,890 Views)
Accepted by topic author vicens
Hi vicens,
How much easier do you want that?
When you look for "missing" data, then you can search for that in two ways:
  • "step by step": go through your (ordered list of) elements and detect missing elements
  • "check them all" by comparing with a list containing all expected elements
The linked thread uses the 2nd method, but you can also implement the first one!
I prefer to "hide" missing elements by using an Y value of "NaN" instead of "zero"…
(1,887 Views)
Thank you GerdW,
I thought using Y values with a date format the T-axis of the graph would autoadjust automaticaly. It looks like I was wrong.
So, as you suggest me, I will follow the "step-by-step" procedure, filling the missing elements and adding the NaN value.
Best regards
vicens
(1,868 Views)
