DSC Tag Configuration Editor - Export/Import String Tag bug?
In the Tag Configuration Editor of DSC 7.1, I enable the "Log Data : On change" option for a string tag. Then I save the .scf File and export it as text file. Then I delete the old tag configuration and import the text file. The "Log Data" option is changed to "Always". Can anybody confirm this? It is not mentioned in the support area.
Alex
(3,305 Views)
I duplicated your procedure, but found that my string tag imported with the log data option as "On Change" just as I had exported it. Not sure why it's behaving that way for you.
(3,295 Views)
