Read from binary file into a cluster array
Hi everyone
I need help with reading the contents of a binary file into an array of clusters . Now this cluster has 5 members that have datatype u32 and a FIXED SIZE array of u8(SIZE of Array is 64).
There are so many thoughts on related queries, I thought if I can get specific I will get help on what is best for my case .
Also fixed size of the array is something about which I am concerned.
Thanking you all in anticipation.
Sumit
Message 1 of 11
(6,927 Views)
@sumitrishi wrote:
Hi everyone
Sumit
Best would be to create a VI which reads one record a time. First use a Read File node with the "byte stream type" input wired with an U32 constant and the "count" input with a constant 5. Depending what application wrote these data files you may have to pass the resulting U32 array trough the "Swap Bytes" and "Swap Words" function. LabVIEW always assumes that data is written in Big Endian format. If the application which wrote the file is a DOS or Windows app it is likely that the data is saved in Little Endian format.
A second Read File function with "byte stream type" input wired with an U8 constant and the "count" input with a constant 64 will read the fixed array.
Now just combine those two resulting wires into a LabVIEW cluster in whatever way you wish and then call this function in a loop to read all your records.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 2 of 11
(6,895 Views)
Thanks Rolf!
I think that is what I have been thinking of doing but was hoping there was an easier way something like a type cast being able to accept this cluster of mine.
Because I had diluted my problem to make it more easier for all to understand .
I actually have 25 members in cluster first 23 are u16(17 in number) and u32(6 in number) jumbled
and then 24th member is an array of u8 of size 64.
and 25th is the u16 member.
I am taking care of the little<> big endian conversions.
Sumit
Message 3 of 11
(6,887 Views)
Hi Sumitrishi!
I'm attaching a VI (written in LV 7.1) that does what you are referring to! In this VI, I create some sample data (according to your specs), convert it to binary data, and reconverts it back to the original data type. The main functions used are Flatten to String & Unflatten to String.
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
Message 4 of 11
(6,884 Views)
Thanks Travis.
I am using LV 6.1 . Does this VI uses features from 7.1 which are new ? If it does not can you please convert it into 6.1 and share it with me .
Thanks again ,
Sumit
Message 5 of 11
(6,878 Views)
Hi Sumitrishi!
No, this VI doesn't use anything native to LV 7.1. I've converted it to a LV 6.1 VI and attached it below.
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
Message 6 of 11
(6,860 Views)
Thanks for the help but according to my problem the first flatten to string is getting binary string/value (which in turn is being read from a file ). In your case flatten to string is getting an array of clusters.
With my case the unflatten from string gives an error.
Sumit
Message 7 of 11
(6,855 Views)
Here is the VI that shows what I meant by my previous posting.
Sumit
Message 8 of 11
(6,854 Views)
Check this out. Adapt to cluster type to whatever you need.
Rolf Kalbermatter
Message 9 of 11
(6,846 Views)
Thanks Rolf will try this approach.
Sumit
Message 10 of 11
(6,841 Views)
