DSC : bad quality on remote OPC item
I am using LabVIEW DSC 8.0.1.
I added an I/O server within my projet. This I/O server is connected to a remote OPC server.
DCOM is well configured since :
 > I get a good quality status when monitoring items in an OPC client
 > I get a good quality status when binding directly on the remote OPC server
When binding a variable to the I/O server, I can select any item (the remote OPC server starts).
When deploying all libraries or running a simple VI with this variable as indicator, the remote OPC doesn't start and I get a bad quality status.
I tried to do the same with DAQmx OPC and an NI board, I have the same results.
Did anybody success using I/O server connected to remote OPC server ?
Help needed...
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
(5,332 Views)
Hello Mr Schricke,
You can find, in the link below, a post forum with the same problem:
http://forums.ni.com/ni/board/message?board.id=170&message.id=176166&view=by_threading&page=1
I think that you already contact National Instruments for his issue
Sanaa T
Sanaa T.
National Instruments France
(5,292 Views)
Sanaa,
I think it is not exactly the same problem.
In fact I posted this message before opening support request #358854 on which you have been working.
Could you add a comment (expected solution) for other users who are may be facing the same problem... ?
Jean-Louis Schricke
Jean-Louis SCHRICKE
(5,290 Views)
As workaroud for this problem, you can use the Data Socket to get the value and quality from the OPC Server.
This is a known issue for National Instruments that will be fixed on the next version of LabVIEW DSC 8.20
Sanaa T
Sanaa T.
(5,280 Views)
