DSC module runtime license and Modbus library
Do I need to have DSC Run-Time license to deploy executable that uses ow-level Modbus API introduced in NI LabVIEW 2014 ??
When I want to use Modbus IO or OPC servers that license is required. In that case I can't find this information
Thanks in advice
Message 1 of 11
(5,614 Views)
What Modbus API are you talking about being released with LabVIEW 2014?
If you are talking about the Modbus library here https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019 It has been around since about LabVIEW 7.  You do not need the DSC runtime license.
If you are using DSC https://www.ni.com/en-us/shop/product/labview-datalogging-and-supervisory-control-module.html, where you can set up libraries of variables that communicate directly with other devices through modbus, then you will need the DSC runtime license.
Message 2 of 11
(5,589 Views)
RavensFan,
There is a Modbus API that now comes with either the DSC Module or the Real-Time Module.  When you install either of these you will see the modbus functions appear under data communications I believe.
Because the functions come with the RT Module though I am not sure if you would actually need DSC Run Time
Message 3 of 11
(5,580 Views)
Thanks.  That is news to me.  That is a new feature I never saw highlighted anywhere.
Message 4 of 11
(5,574 Views)
The only place I saw it mentioned was in the Introduction to Modbus white paper where it mentions half way through that in 2014 it's included as part of two modules even though the functions don't appear under either section in the functions palette.
https://www.ni.com/en/shop/labview/introduction-to-modbus-using-labview.html
I just found this out like 1 week ago so it probably wasn't very well highlighted.
Message 5 of 11
(5,563 Views)
I am talking about Modbus lib that comes with LV 2014
It says that is included in DSC and RT module. So as I understand DSC RT lisense isn't required in that case??
Message 6 of 11
(5,548 Views)
I'm pretty sure you'll need the RTE.  But, there's a simple test you can do to determine if this is correct.  Build a simple project that uses the library.  Create an executable.  Try to run it on a second computer that doesn't have the development system.  If it works, you're set.  If not, you'll want to talk to NI about the RTE.
Message 7 of 11
(5,537 Views)
you'll need the labview runtime of course, you shouldn't need the DSC runtime unless something drastically changed. It should have identical licensing to the modbus I/O servers, which simply require that you own a license to DSC or RT.
Message 8 of 11
(5,523 Views)
If it's a part of the DSC, you'd certainly need the DSC RTE.  A "drastic change" would the DSC Module not requiring the DSC RTE to run on a deployment PC as it's always required the DSC RTE.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LRUSA2&l=en-US Originally published in 2010.
Message 9 of 11
(5,515 Views)
I have the same questions.  Does this Modbus library require LV DSC RTE in order to deploy?
I see the community's answers to this question are conflicting.  Some say yes.  Some say no.  Anybody have a definitive answer?
http://www.medicollector.com
Message 10 of 11
(2,003 Views)
