DSC
WHY i can not install DSC in win 7 64bit?
how can i install it?
(4,630 Views)
You can.  Or at least I can.  I have Windows 7 x64 with DSC 2012 SP1 installed for LabVIEW 2012 SP1 32-bit.  What versions of what stuff are you trying?  What is preventing you from installing?
(4,604 Views)
WIN7 62BIT:i can install DSC based on LV 2012 32bit ,but i can not install DSC based on LV 2012 64bit .
(4,594 Views)
Accepted by topic author changewell
Refer to: https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil... to see which modules are supported in 64-bit.  DSC is not one of those.  That is why you're having issues installing it with the 64-bit version of LabVIEW.  Install the 32-bit version and you'll be able to use this module, as others have suggested.
(4,584 Views)
