FGEN Arbitrary Waveform Normalization
I have been using the "Open Front Panel" option of the FGEN Arb Express VI to help me construct my own Arbritrary Waveform VI.  I noticed in the Express VI, there is a piece of code that appears to normalize the waveform.  I think this is affecting my output in undesirable ways.  Is this code necessary?  I am using the 5421 which has a 12V limit, so I don't think I need to normalize to 1 volt.
Thanks in advance for any advice.
-Billy Maier
(3,549 Views)
Forgot to include the image and I couldn't see the edit option for some reason on the opening post.
Sorry for the bump.
(3,514 Views)
The normalization has to be there. The NI-FGEN Create Waveform (WDT).vi needs to have the input waveform in the range of -1 to 1. Use the gain parameter to get your signal to the amplitude that you need.
Noah | Applications Engineer | National Instruments
(3,503 Views)
