DSC
Hi
I’ve Server and multi client in the Server I Install LabVIEW and DSC
In the client I don’t install LabVIEW and DSC
I want read the historical data from the clients.
We should install DSC in the client or we don’t ?
Or we should Install only LabVIEW run time engine and DSC engine?
Regards
(2,958 Views)
Hi Spring,
You should install the LabVIEW run time engine and the DSC run time engine on the clients.  You can add both as additional installers for your project.
Jeremy_B
(2,920 Views)
