LabVIEW FPGA 8.5.1 & Spartan-3E starter board (error 1063)
I can successfully run example VI’s on my Spartan-3E starter board, but as soon as I try change/add an FPGA I/O (for example to an expansion slot) I get code generation errors: Error 1063 occurred at an unidentified locationPossible reason(s):LabVIEW: Specified terminal not found in object I’m new to LabVIEW FPGA but not LabVIEW.Please Advise
(2,800 Views)
Patty_G,
Please take a look at this post, it describes a very similar situation, but with different hardware. MehakD's solution seemed to resolve the issue, but save your old EIONode in case it does not...
http://forums.ni.com/ni/board/message?board.id=280&message.id=3652&requireLogin=False
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,758 Views)
