DSP Target - TI DSK 6713 Compatibility
Is TI DSK 6713 compatible with LabVIEW 2010-2012? I know it is compatible with 8.6; I am currently using LabVIEW 2010 University Academic Suite; the only DSP target support for newer version suggest to use FPGA targets.
What would be a best solution to use LabVIEW program the TI DSK 6713 DSP target? Do I need to download additional drivers?
(2,996 Views)
Hello Alias5m5,
As you mentioned the TI DSK 6713 is compatible with LabVIEW DSP 8.6, and LabVIEW 8.6, however LabVIEW DSP for TI DSKs has been end of lifed as a product and is no longer supported.
Unfortunately, as the DSP Module for TI DSKs is end of life, it may not be compatible with newer versions of LabVIEW.
Joel
(2,976 Views)
