software controlled event
I have  a problem of generating software triggering of an event. The VI is attached with the post. It in LabView 8
Loop # 1 generates an array of 100 random numbers. Now what I want is that "just when the array is complete, It must  trigger the structure below. The array data must be passed to the local varible "Array" in the event structure and is displayed in the waveform graph and Intensity chart.
the event structure must stop then, until the next array values arrives. The process must be as effecient as possible.
Simialarly, Kindly let me also if there is any other effecient way of data transfer in between instead of Local variable method.
Will be waiting for an early reply...
Regards;
(2,594 Views)
Duplicate.  Please use this thread.
Lynn
(2,591 Views)
