Error to query machine for data using :FORM:BORD NORM;DATA REAL, 64;:DATA?' code
I am trying to extract the data measured by instrument using :FORM:BORD NORM;DATA REAL, 64;:DATA? code. It seems to work pretty fine for some data stream in which it can read #6000808. However, for some data  stream it read it as ÿÿÿÿÿÿÿ. Specifically it just happen when it reads a constant source SMU measurement. There is no error to read a variable source SMU measurement.
May i know what does it meant and how to correct the error?
The coding used is as below
Thank you in advance,
Regards
jaz
Message 1 of 1
(2,421 Views)
