DWarn 0xD8C68272 Reserve count (xxx) should be the same as the number of top-level reservers (xxx).
can someone please explain this DEBUG output from the lvlog.txt file. What is the reason for it ?Thanks
<DEBUG_OUTPUT>
02.04.2025 11:20:25.594
DWarn 0xD8C68272: Reserve count (1) should be the same as the number of top-level reservers (3). [LinkIdentity "Calculus.lvlibp:Calculus Item Interface.lvclass" [ Main Application Instance]
source\UDClass\OMUDClass.cpp(1978) : DWarn 0xD8C68272: Reserve count (1) should be the same as the number of top-level reservers (3). [LinkIdentity "Calculus.lvlibp:Calculus Item Interface.lvclass" [ Main Application Instance]
[ExecSys:0; Executing:"[VI "Kernel.lvlibp:Load Plugins Dialog.vi" (0x266b6b70)]"]
</DEBUG_OUTPUT
0x679D87F3 - lvrt <unknown> + 0
0x681D5796 - lvrt <unknown> + 0
0x681B8F09 - lvrt <unknown> + 0
0x67F3DB1E - lvrt <unknown> + 0
0x6800AB0D - lvrt <unknown> + 0
0x6800ADB7 - lvrt <unknown> + 0
0x6800ADA1 - lvrt <unknown> + 0
0x67F12F82 - lvrt <unknown> + 0
0x67F12FC4 - lvrt <unknown> + 0
0x67F139E8 - lvrt <unknown> + 0
0x67F12D64 - lvrt <unknown> + 0
0x67F3DB01 - lvrt <unknown> + 0
0x6800AB81 - lvrt <unknown> + 0
*** Dumping Bread Crumb Stack ***
*** LabVIEW Base Address: 0x67930000 ***
#** Loading: "C:\MEVAS\Novibra\PPL\Statistics.lvlibp\Plugins.vi"
*** End Dump ***
(1,142 Views)
Same problem here in LabVIEW 2019 SP1:
<DEBUG_OUTPUT>
25/11/2025 15:46:39.862
DWarn 0xD8C68272: Reserve count (109) should be the same as the number of top-level reservers (117). [LinkIdentity "BufferReader.lvclass" [ Instance d'application principale]
source\UDClass\OMUDClass.cpp(1978) : DWarn 0xD8C68272: Reserve count (109) should be the same as the number of top-level reservers (117). [LinkIdentity "BufferReader.lvclass" [ Instance d'application principale]
[ExecSys:0; Executing:"[VI "Get LV Class Default Value.vi" (0x1c17c5c8)]"]
</DEBUG_OUTPUT>
Any infos regarding this error ?
Cheers,
Amaury.
Responsable projet LabVIEW Système Embarqué chez NERYS, CLA et CLED
(78 Views)
