Daq Assistant : Frequency per channel ?
I am using the Daq Assistant ( labview 7.1) to acquire 8 Voltages. Could anybody tell me if the "frequency" mentioned in the Daq assistant is per channel or the global frequency of the acquisiton ( that I have to devide by 8 to calculate the frequency per channel ) ?
Thanks a lot,
Marc
(2,612 Views)
The frequency option in the DAQ Assistant refers to the frequency that each channel will acquire at. However, with the DAQ Assistant, you can only set one rate for all of the channels you are acquiring on. That tool is really meant to build quick and simple measurements. If you want to set up different rates for each channel, you will need to use the standard DAQmx VIs.
J.R. Allen
(2,578 Views)
