pass a pointer to an array from Labview to OCX (activex)
I am trying to pass an array of interegers to the ocx (activex) using a pointer or a handle. How do I do that?
Should I create DLL first, or can I use existing ocx with some additional functions?
I don't have any experience with this kind of programming, please help ...
(3,387 Views)
You can put an ActiveX Container on your front panel that contains the OCX object. Now on your block diagram, use Automation Open function (All Functions>>Communication>>ActiveX)to get an ActiveX refnum to this object. Wire this to a property node/invoke node (also found in the same palette). The object should have some property /method like 'set value' that would let you wire in an integer array to it (you might need to convert the array to a variant first).
I hope it'll help.
Ankita A.
(3,371 Views)
Hi Ankita,
thank you for helping.
I tried what you suggested. I have a "Write Block to..." method that uses the pointer to array input. If I connect array, or array transfered to variant, into this input - I get an error. Obviously, I have to give it a real pointer, not a variant or array.
Any other suggestion?
(3,360 Views)
Hi Vlade,
I guess then the other option would be to write a dll that takes in the array as input. Within the dll, you would need to access the ActiveX control.
Hope this helps.
Ankita
(3,342 Views)
