Daq assist
Is it possible to wire the ouptut data from a daq assist to the stop terminal of a while to get the program to stop running? I have wired a switch to the digital input line 0 of MyDaq so when the switch is made im getting 5 volts in. I can get it displayed as an indicator but cant wire it up to the stop condition
(2,645 Views)
Accepted by topic author bobby.m
Your daq assistant is probably giving you the blue dynamic datatype wire which is pretty much useless except to connect to other Express VI's.
What you need to do is convert the blue wire to a boolean.  Look at the From DDT function (which happens to be an Express VI) on the Express >> Signal Manipulation palette.
(2,643 Views)
Got it working!
Thanks Raven Fan
(2,636 Views)
