DaqMX create channel
@DavideB wrote:
Now I have the problem to connect the task out and error out pins of two DaqMx read objects. How can I fix that?
No, you have two different tasks.  Each task should have its own read.  You can use Merge Error if you want to combine the errors.  But the task wires should remain separate.
Message 11 of 22
(1,254 Views)
I merged the errors because I cant think of any other alternative to manage them.
But what about the tasks? I have two DaqMX read objects. Task should go into the DaqMx clear task (I think), which is one. Should I have two? If yes, how can I connect the previous code to them? now it is only one flow and I dont want to duplicate the whole code.
Message 12 of 22
(1,238 Views)
With two tasks, you need two clears.
Or at least, you need to call DAQmx Clear for each of them.
If you have several operations to carry out on both, you could build an array of the DAQmx Task wires, and pass that to a For loop, but usually I just place two sets of things to clarify intent. If you have lots of operations (Stop, Clear, check for specific errors, format a message saying a task ended etc) you could just use a subVI and place two copies of the subVI for example.
GCentral
Message 13 of 22
(1,232 Views)
I have just two DaqMx read, so I will use two clear tasks at the end.
Still, I had to merge errors, because otherwise it seems to me I had to duplicate all the previous code.
I think this solution is ok (I attach the code for reference in case, sub-vi RDI is just a Daqmx read plus some algebra).
Thanks for your support
Message 14 of 22
(1,229 Views)
I'd suggest trying to straighten out some wires, but otherwise that looks fine to me 🙂
GCentral
Message 15 of 22
(1,222 Views)
Straighten out wires?
i assume it’s just an esthetic thing..
Message 16 of 22
(1,221 Views)
Hi Davide,
@DavideB wrote:
I think this solution is ok.
Some more improvements:
  1. Replacing the ConcatString and several FormatString functions with a single FormatIntoString with a proper format string.
  2. Also note that "MISSING LABEL" at one of your controls: NEVER delete the label! (It's ok to hide it in the frontpanel.)
  3. You don't need to unbundle the Status of the error wire for an OR function…
  4. Right now you wire the error cluster through your FOR loop and also through the WriteFile function: when there is an error upstream you will not write data to your file! Maybe you need to change that error handling a little bit…
Message 17 of 22
(1,218 Views)
Thanks for your suggestions,
but if I unbundle the error I get an error, at least with my old version of Labview.
I understand from your previous post I should handle errors differently, but I dont know how..
Message 18 of 22
(1,202 Views)
Hi Davide,
Which LabVIEW version do you use?
On error handling:
When you want to save data to file even when one of your two DAQmx tasks gives an error then you should NOT wire that error cluster into the WriteFile function: when an error is present at error in it will not write any data…
Message 19 of 22
(1,187 Views)
I use labview 2010
Message 20 of 22
(1,173 Views)
