DaqMX create channel
>When you want to save data to file even when one of your two DAQmx tasks gives an error >then you should NOT wire that error cluster into the WriteFile function: when an error is >present at error in it will not write any data
I understand this... but should it write the data at all if there is an error?
Would you rather go around the for loop with the error wire and plug into the OR function directly from merge errors (after RDI subvi)? Thanks
Message 21 of 22
(368 Views)
Hi Davide,
That depends on your requirements…
I guess you should write data even when one of your two tasks is giving an error!?
Message 22 of 22
(357 Views)
