DaqMx two digital output module synchronisation
How Can I synchronize (Hardware synchronization) between two digital output modules using a digital input trigger
(it means that the digital input module is the master and the two digital output modules are slaves)
I am using C series modules on a compactdaq
Thank you
(2,411 Views)
Accepted by Labview_user94
I've done it using a "wire" (in my case, stranded copper covered with a plastic insulation, bared at the end and connecting a Digital Out terminal to two Trigger Inputs).  If your DAQs are triggered, you simply take your Digital Out and give it a True (to make it go High), wait a msec, then make it go low.  If your "triggered DAQ" devices were wired to start on "Rising Edge", they will both start when you send the True to their Trigger DO.
(2,401 Views)
