Daqmx tasks running in parallel loops - LV8.5
You are not running parallel tasks on the same hardware. You have an analog input task and an analog output task. If you tried two analog inputs or two analog outputs, you would get an error.
Message 11 of 13
(1,227 Views)
You have two task, one analog input and one analog output.
You are allowed to have one input and one output.
You can not have 2 analog input tasks, only one of each.
Message 12 of 13
(1,224 Views)
Thanks a lot...that clears things up.
Ken
Message 13 of 13
(1,217 Views)
