Darren's Occasional Nugget 01/05/2018
Thank you Darren for bringing that up to the community.
And re-starting the debate on "Wait with Error Functionality"
I've had a fairly bullet-proof routine around for a long, long time. available in the code sharing repo.
I took the time to publish an update over here as their have been some improvements made over the years.
Cosmetically, its nicer Seconds to Wait is now a DBL, and the original was never "In-lined" since that was not available back then.Delay.png
Message 11 of 24
(2,942 Views)
How difficult would it be to add a Boolean input into the bottom of the Stall Data Flow.vim ?  Have the Boolean if unwired, resume the current state of 'delay regardless of error' ; otherwise, on the change of the Boolean state have it skip delay on error.
Just my $0.02
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 12 of 24
(2,864 Views)
Just my $0.02
So, do it!  Rename it and place it in your personal reuse library.  No need to muck up a perfectly functional and well documented vim in vi.lib
Message 13 of 24
(2,861 Views)
True!  And you don't have to include it in your Project, as it's on the Quick Drop menu.
BS
Message 14 of 24
(2,701 Views)
How's this?
Separate data flow and error flow.
If you want unconditional wait, wire to "Data In", leaving "error in" unwired.
If you want to wait only if there is no error, wire to "error in"
Also, time value is independent of units.
Message 15 of 24
(2,657 Views)
@paul_cardinale wrote:
How's this?
I would probably go the route of just not waiting on an error and use the new Type Specialization functions.  Only one set of controls instead of 2.
Message 16 of 24
(2,631 Views)
@crossrulz
I like your mod, but why not take it one step further and also use the other new Type Specialization function. That way you can use an error wire or any other wire if necessary.
mcduff
Message 17 of 24
(2,585 Views)
I did.  Did that not come through when you opened my VIM?  I did do a save for previous to get it into 2017, so it is possible it was lost.  Just checking really quick, and I see it in the VIM I posted.
EDIT: Ok, I see it now.  The Save For Previous changed the Type Specialization Structure into a Diagram Disable Structure.  Attached is my original 2018 version.
Message 18 of 24
(2,567 Views)
I was wondering why that disable structure was there, good to know Save for Previous changes some things about VIMS.
mcduff
Message 19 of 24
(2,558 Views)
@FabiolaDelaCueva wrote:
Where do we start the campaign and signature gathering to convince Jeff K that we should make it not wait if there is an error in?
Here: Stall Data Flow should be a no-op in the event of an error
Message 20 of 24
(2,219 Views)
