Darren's Occasional Nugget 09/26/2022
Here's one even faster.  Might be the fastest in this topic yet. (optimized XML un-escape)
Message 31 of 61
(4,393 Views)
I don't see much difference in timing:
Ettepet (fastest)= 0.180248
Darren = 0.179282
Ooth = 0.194544
But there does seem to be a problem with Ooth's implementation.
BTW. I am not a fan of your "compressed" coding style and would never use it as-is. 😱
Former Certified LabVIEW Developer (CLD)
Message 32 of 61
(4,335 Views)
Shorter wires means the electrons flow faster, and have less resistance, making the program run faster.
Spoiler
This is a joke, please don't do this thinking it will make it run faster.
Message 33 of 61
(4,329 Views)
"Electrons"?  I thought they were datons.
Message 34 of 61
(4,304 Views)
I prefer to have my code fit on a normal pc screen (more or less), not 3 or 4 screens wide. 😆
Thanks for the timing comparison!
Darren's solution probably is a bit quicker because it doesn't do XML-unescape or regional number-formatting.  Couldn't tell from the "protected" code he uploaded. 🙂
Message 35 of 61
(4,304 Views)
I only uploaded one VI, in my original post. It was documented and not password-protected.
Message 36 of 61
(4,293 Views)
Sorry for that, end of the day.  Thanks for your original code b.t.w.  I can now have Excel files open in Excel while importing data, which is a great help.
...so that means its slightly faster time comes from not doing XML-escaping, regional-number formatting etc.
Message 37 of 61
(4,266 Views)
Anyone opposed to me turning a version into a VIPM package? I presume DNatt doesn't mind if I start from his, want to check with others. I would link to this forum in the package description.
Message 38 of 61
(3,910 Views)
Sounds great, thanks for doing this Derrick. My preference would be that you use my original VI (I did not see anybody report any bugs with the original version in this thread), and credit me as the author.
Message 39 of 61
(3,904 Views)
If your original post does do XML-escaping, regional-number formatting etc. you would be correct.  If it doesn't you would need to correct that.
I will continue to use mine, which also has some efficiency improvements and fits on my display.
Message 40 of 61
(3,860 Views)
