Darren's Weekly Nugget 04/24/2006
While discussing one of my previous nuggets, another cool tip came up, and I was asked to make it a full-fledged nugget, so here goes.  If you design a VI icon in another application (like Microsoft Paint), you can drag the image file from Windows Explorer or your desktop into the icon image area in the upper-right corner of your VI window.  This will automatically update the B&W, 16, and 256 color icons of the VI.  I just tried with several image file types...this nugget works with BMP, JPG, GIF, and PNG files.  It does not appear to work with TIF files.
-D
P.S. - Check out past nuggets here.
(8,163 Views)
Is there a size limitation on the image file used based on readability once transferred to the VI Icon?
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(8,154 Views)
Is there a cool tip that will be able to transfer the image directly from my head into the icon? Smiley Very Happy
Just joking, of course. We're a long away from Hal at the rate we're going...
Useful tip, as always.
(8,149 Views)
I don't think there is a size limitation...if the image you attempt to drag is greater than 32x32 pixels in size, I believe it will be shrunk to fit in the 32x32 square.
-D
(8,136 Views)
Just thought it'd be worth mentioning that, while I haven't tried it, I expect the supported image file types might vary slightly on non-Windows systems.  Most notably, BMP might not work, but I'd expect the others Darren mentioned would.
Message Edited by Jeff B on 04-25-2006 07:14 AM
(8,089 Views)
Hey Darren,
I just played a bit with with it and found, that LV8 resizes even those with aspect ratios other than 1 and large pictures of 1000x500. This is very good work by the NI- guys.
Andf then I noticed, that the image put into the clipboard, when you make "select all" & "copy" in the Icon- Editor, now has the right size of 32x32, so you can make a new picture of it in Paint Shop Pro. This didn't work correctly in former LV- versions (ok, I jumped over from LV 6.1, so I don't know about LV 7).
Dave
Greets, Dave
(8,010 Views)
