Darren's Weekly Nugget 05/03/2010
Darren wrote:
Ben wrote:
The text layer is only really good if you are doing only blank icons with text only.
I find it to still be useful with right-justified text on the read/write glyph-based icons for LV class data member access VIs:
Right-justified ! Doh!
Thank you.
Ben
Message 11 of 13
(1,059 Views)
Thank you.
Ben
Hmmm... What is wrong with left-justified text?
Message 12 of 13
(1,047 Views)
The icons are created by default with the glyphs in the upper left corner. Right-justified text just means you don't need to manually move the glyphs from their original positions.
Message 13 of 13
(1,043 Views)
