Darren's Weekly Nugget 06/07/2010
One of the primary reasons we use error clusters in our diagrams is to enforce data flow.  But another (more obvious) reason is that we want to propogate error information through our code.  If an error occurs upstream, we usually do not want downstream functions to execute.  The vast majority of LabVIEW VIs and functions will not execute if they receive an incoming error.  But there are many that still execute, even if they receive an incoming error.  Here is a list of several that come to mind:
  • Close Reference
  • Close File
  • TCP/Bluetooth/IrDA Close Connection
  • VISA Close
  • TDMS Close
  • Release Queue/Notifier
  • Close Config Data.vi
  • Close Zip File.vi
  • Release/Acquire Semaphore.vi
Do you see a pattern?  🙂  Most of these are functions that Close or Release something...it makes sense that, even if an error occurs, you still want to close references and/or release memory assigned to something.  But what about that last pair?  It would seem that even Acquire Semaphore.vi will execute with an incoming error.  So what is the easiest way to determine if a VI or function will still execute, even with an incoming error?  By reading the LabVIEW Help for the function:
Every LabVIEW VI and function that executes even with an incoming error will have this sentence in the error in parameter description in its online help.  And if you find a VI or function that does not behave as described, then we either need to fix the help or fix the function, so make sure to let us know.
Message 1 of 14
(9,652 Views)
Yeah. Good luck with getting people to do that. Smiley Very Happy
Message 2 of 14
(9,616 Views)
IMAQ Dispose is a VI that presumably should execute despite an incoming error, but doesn't.
Doing a quick search in the LabVIEW help for "runs normally even if" shows a reasonable number of other VIs that also execute with incoming errors, but they're not ones that close or release anything.  They are mostly from the Storage palette (e.g. Create Query, Merge Queries, ID to Refnum ...), the Digital Waveform palette (e.g. Digital Comparison, Analog to Digital, Append Digital Samples ...) or the Waveform Generation palette (e.g. Poisson Noise Waveform, Bernoulli Noise Waveform ...).  Is there any criteria for determining which VIs should behave like this?
Message 3 of 14
(9,589 Views)
The only general criterion that I know of is that close/release functions tend to behave in this manner.  Different APIs are going to implement error handling in different ways.  That's why I recommended reading the help for the functions in the APIs you're using to verify their behavior with error conditions.
Message 4 of 14
(9,575 Views)
Thanks for that one Darren.  I've always included a 'shutdown2' state in my code that was basically the same thing as 'shutdown' except without the error wires connected.  It ran when 'shutdown' reported any errors just to be sure everything was closed before the main program terminated.  Now I can see why that was superfluous.
I guess I should learn to RTFM a little more carefully.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 5 of 14
(9,564 Views)
Good one Darrin.  Even better one smercurio !!!!!
- tbob
Inventor of the WORM Global
Message 6 of 14
(9,563 Views)
Its a pretty big manual.... /sigh.  Even when I do read about a function thoroughly, I still miss stuff.
Message 7 of 14
(9,557 Views)
Actually, it does. Try it 🙂 The documentation should probably be updated.
CLED (2016)
Message 8 of 14
(9,525 Views)
Read LabVIEW help = forum will become obsolete Smiley Very Happy
Message 9 of 14
(9,351 Views)
Here's another function that will run when an error is present on the input....
 Smiley Tongue
Message Edited by Broken Arrow on 06-08-2010 03:25 PM
Richard
Message 10 of 14
(9,285 Views)
