10-06-2006 08:57 AM
10-06-2006 09:02 AM
Hi TiTou,
I am confused.
It looks like you are talking about entering enum values.
Stephen's nugget talks about text wrapping in a string constant.
Ben
10-06-2006 09:10 AM - edited 10-06-2006 09:10 AM
Message Edité par TiTou le 10-06-2006 04:11 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
10-06-2006 09:12 AM
The solution to that should be adding a scrollbar to the comment object. A more generalized solution would probably be getting rid of the comment object and simply using a string constant all the time, but then you would have to change its appearance when you're using a "comment" and you would probably need a property to tell the editor that you can't wire out of that object and at that point it might become too much too handle.
@Ben wrote:
I went to the VI Checklist to try to find the note that said that if you are entring a lot of comments, that it is recomended that you use a string constant with the scroll bar showing. Well it appears that note has been deleted. So what used to be good is now bad.
10-06-2006 09:16 AM
tst wrote "The solution to that should be adding a scrollbar to the comment object."
I agree.
The good news is the code to do this already exists and JUST* needs implemented in the comments.
Ben
* When you code by the hour, "JUST" is a four letter word. ![]()
10-06-2006 09:22 AM
