Darren's Weekly Nugget 11/15/2010
I'm not a big fan of Auto Grow on structures:
I have deselected Tools > Options > Block Diagram > Place structures with Auto Grow enabled so none of my VIs have the option selected.  But sometimes I inherit code, and I am perturbed when stuff starts moving around on the diagram because the original author liked auto grow.  So I wrote this utility VI that will turn off Auto Grow on all structures in all VIs in a given folder:
Make sure to backup your VIs before running this utility.
Message 1 of 10
(10,150 Views)
If you don't have auto grow turned on, how do you make sure you don't wind up accidentally hiding things beyond the edges of the structures?
Message 2 of 10
(10,112 Views)
Kudos for the great example that could act as a springboard for any type of VI batch processing! I must make two minor mods to the VI to make it more palatable to my own (and Ravens'?) taste:
Message 3 of 10
(10,098 Views)
An excellent springboard, indeed.  Here's a tweak that turns off "View as Icon" for all BD terminals.
-Barrett
CLD
Message 4 of 10
(10,071 Views)
I ❤️ scripting.
Message 5 of 10
(10,054 Views)
I run the "Hidden Objects in Structures" test from the VI Analyzer Toolkit on my code as part of my nightly build.  Doesn't everybody?  😉
Message 6 of 10
(10,033 Views)
Ohooooo.......Scripting all the  way.
Darren Thanks for the Nugget
Ohiofudu
CLD.
Certified LabVIEW Architect.
Ohiofudu Israel
Message 7 of 10
(10,024 Views)
Same concept: are all enums type def'ed?
Felix
Message 8 of 10
(9,994 Views)
Glad to see that I'm not the only one who dislikes autogrow.
Nice nugget.  I'll have to borrow this code and put it in my bags of tricks.
Message 9 of 10
(9,935 Views)
Turn on Show Warnings by default.
SULLutions.com
...when a single discipline is not enough
Message 10 of 10
(7,050 Views)
