Data Acquisition Issue
I have created a program that logs vacuum and temperature of a product.  I want to continuously display the live data on a graph but I noticed that when the program is running, there are breaks in the vacuum waveform (blue line).  It is as if data is not being logged or read periodically.  I tried playing with the sample rate but nothing helped. Any advice is appreciated.  Thanks!daqissue.PNG
(3,453 Views)
Do you see any errors?
I have had issues in the past sampling too slow. This may be causing part of the problem. I would also suggest that you offload the processing and saving of the data to the bottom loop. Have the data stream to a control them process it somewhere other than the loop you are using to do the data acquisition. You may have to over sample a bit and then average to get the card to give consistent data flow.
How do you have the channel connect to the 9201?
Tim
GHSP
(3,444 Views)
Accepted by topic author ANON12345
1.  Since all of your modules seem to be on the same chassis, you should be able to just create 1 task for all of your channels.  This will make your code quite a bit simpler.
2. Use a Producer/Consumer setup to move your logging to another loop.  This will allow your DAQ loop to keep a good, steady pace while you just log the data when it comes in.
(3,431 Views)
I used 1 task for all my channels and it fixed the problem.. Thanks,
(3,393 Views)
