Data Acquisition counting number of Iterations
I am attempting to put a column in my spreadsheet and also on the front panel counting the number of data points that I have taken. As you can see in the picture I was the first column to be the iterations count, but I cannot figure out how to make this work. I attempted a for loop outside the while loop using the increment function, but it overwrote all the data and was count 1-11 for each column instead of making measurements.
(2,113 Views)
Accepted by sambpk
Use the "i" (the iteration) from the while loop, convert it to a string, concatenate it just like, and before, the time stamp.
(2,100 Views)
