Data Aquisition from HP 54504A
I have an older model HP 54504A Digitizing Oscilloscope, and I need to create a LabVIEW program that can pull data off the scope. I also need to be able to capture an eye-diagram, which will require repetitive sampling to acquire a large number of data points. I was wondering if anyone had a simliar program that I could use as a reference in create mine. Thanks in advance.
(2,661 Views)
Hi Trigeek,
I do not have personal experience with this device, but you might check this site for a driver for your instrument. I'm not sure if there is one for this instrument or not but you might be able to find a driver for a similar instrument that you can modify. Maybe someone else who has experience with this instrument will post an example for you. Hope this helps.
JenK
(2,647 Views)
