Data Dashboard - How to modify Indicators
Hi all,
I have two Questions.
- Are there packages available to download more Controls/Indicators for my data dashboard app?
- I want to show a 360 rotary sensor on the dashboard with the gauge indicator. But this one has a gap between the 360 and 0.
In LabView you can easily drag and drop the 360 on top o the 0 so you will have a full rotation.
How can I do that on the dashboard?
There are many rotary systems in the world NI. We really need that feature 😃
Best regards
Bastian
(4,005 Views)
you can use text labels in the properties....
(3,978 Views)
I am not talking about the VI. I am talking about the data dashboard app for IOS and/or android. You have limited indicator properties available in the app.
Bastian
(3,963 Views)
Hi Bastion,
- You can't currently remove the gap at the bottom of the gauge, but I have made a feature request for the developers.  It's a good suggestion, and I will discuss it with the project manager.  Thanks for the feedback!
- Data Dashboard doesn't have any packages that can be downloaded to get additional controls/indicators.
Cheers,
Brandon
(3,952 Views)
DataDashboard has it's own board. In the future, you should post questions there.
(3,943 Views)
Ok thank you. I now tried to display the rotation with the XY graph. Works but doesn't look so cool ;).
I posted one more question on the 'hopefully' correct board here:
http://forums.ni.com/t5/LabVIEW-Web-UI-Builder-and-Data/Shared-Variable-Polling-Rate/td-p/2586461
Bastian
(3,926 Views)
