Data Logger Timing and Event Recording Issue
You need a case structure around the logging so that it is only done when one or more of the triggers have tripped.
Message 11 of 12
(545 Views)
Yes, the case structure worked very well. I also changed to the 'export waveforms to spreadsheet file.vi', which works really well in terms of pulling in all of the data I require.
Many thanks.
Message 12 of 12
(529 Views)
