Data Socket
Hi all. Can someone help me with my task? A have problem solving this one, don t have much knowledge about Data Socket. So i would appreciate if someone have solution to share , free time to look on this, ( and also some examples with Data Socket ).
Thanks again
In LabView write two programs that communicate with each other through the TCP / IP protocol (Data Socket). In one VI generate random data - 5 sizes. Design a protocol by which another VI would require one of these 5 measuring sizes and transfer all 5 separately and display on the graphics. Measured data is burned to disk, and on demand it is loaded from the same to the graph.
(3,095 Views)
Hi Bgmnt,
So you have a problem with your homework?
And we should solve your homework for you?
Why don't you examine the example VIs coming with LabVIEW?
Why don't you play with those TCP/UDP/Datasocket example VIs? Just by opening them you would solve 50% of your homework…
(3,037 Views)
