Calling VI script from MATLAB
I wanted to run a VI script from MATLAB, and I looked up the Internet how to do so. I learned that if I used the following commands, I could run a VI.
e=actxserver('LabVIEW.Application');
vipath='c:\Documents\Labview files\test.vi';
vi=invoke(e,'GetVIReference',vipath);
vi.Run
But this gives me an error.
Error using
COM.LabVIEW_Application/GetVIReference
Invoke Error, Dispatch Exception:
Source: LabVIEW
Description: LabVIEW:  Open VI Reference no
longer matches VIs in memory by filename. A
filename is no longer sufficient because the
full name of a VI now includes any owning
libraries.
Error in readColorVI (line 7)
Does anyone have an idea what should I include apart from the file path to get the script running?
Message 1 of 8
(6,466 Views)
Does the script run correctly in the LabVIEW environment?
Chase
NI Technical Support Engineer
Message 2 of 8
(6,407 Views)
Yes, it works perfectly.
Message 3 of 8
(6,397 Views)
Is that particular test.vi using any calls to sub-vis ?
Message 4 of 8
(6,382 Views)
If it works in LabVIEW, I would follow The Math Work's instructions and create a ticket with them if that does not work correctly.
https://www.mathworks.com/help/matlab/matlab_external/run-external-commands-scripts-and-programs.htm...
Chase
Message 5 of 8
(6,367 Views)
The VI does call a sub VI, and that very well could be the problem. If there's a solution to it, I'd be glad to hear it.
If there isn't, then I'll raise a ticket at Math Works.
Message 6 of 8
(6,358 Views)
Accepted by topic author DeepPars
The easiest way to find out is to eliminate the subVI call and see if it still errors.  If so, it's not the subVI
Message 7 of 8
(6,348 Views)
But what is the Win OS system command for running a VI?
Message 8 of 8
(5,832 Views)
