Data Sorting into a array indicator
Hi All,
Currently, my programme is design to make sure of the iteration count of the while loop to act as a counter for the time elapsed. Subsequently i used the increasing value as an input to my cosine and sine graph as shown in the attachment in this post to make it move in a circular motion with a step size of 0.3 radians per second. I will like to make these data more visible as an array indicator. How can i make sure that the data that is processed every second can be stored into this array for future reference? Please kindly guide me along. Thank you in advance guys.
Best Regards
Scott
(2,770 Views)
Hi Scott,
use an autoindexing output tunnel to build your data array...
- Clean up the VI...
- There's a combined Sin/Cos-function...
- What's the point in multiplying a number by 1000 followed by dividing it by 1000?
- the first loop iteration will likely not follow your timing...
(2,763 Views)
