Rotation Into NXT Motors
Hey,
I'm creating a robot and I have a differential for the back so my rear motor just needs to output a constant speed. Using a PD line follow program I need to make it so I can output a degree measurement to turn the front of the robot a positive or negative angle. How might I do this?
(3,103 Views)
First of all, I recommend posting on the "LabVIEW for Lego Mindstorms" forum. You will probably get more knowledgable help there for LabVIEW programming specific to your NXT robot.
I think there is a function available in the LabVIEW for Lego Mindstorms toolkit that allows you to directly specify the number of degrees you want a certain motor to turn. Try looking at the polymorphic Wait VI and selecting rotation.
(3,078 Views)
This article is intended to carry out a program to monitor the status and speed of a motor connected to the NXT Intelligent Brick MindStorm from the front panel on the computer
https://decibel.ni.com/content/docs/DOC-32450
(3,020 Views)
