08-04-2009 01:07 PM
I want to log a mass, a box number, the logged in user, and a time stamp periodically. I would also occasionally log a string describing an event.
The way I see it, there would be a group for each box number and a channel for each entry for the box. Mass, box number, logged in user, time stamp, and event description could all be properties for each channel.
Is this the right tool for the job? I'd be using streaming data format without streaming any data. Writing a CSV file could get the job done. What benefits might I derive from using a TDMS. Are there any pitfalls? Is there another format I should consider?
Solved! Go to Solution.
08-04-2009 01:17 PM
From what I understand of TDMS, it would not be a good tool for this job. The CSV approach will be good to start out and if required you can import the CSV into a DB if your req's change so you have to do searching and reporting.
08-04-2009 01:26 PM
08-04-2009 01:28 PM
Then run and don't look back.
KISS = Keep It Simple Sir
Ben
