Data acquisition software - Do I need it?
Please bear with me, as I am a beginning with LabView.
I hope to interface my hardware (Agilent OSA) with LabView to display waveforms from the hardware with low latency. As of now, I have LabView 8.5, MAX, and a GPIB-USB-HS cable (MAX recognizes my hardware when I connect it). Also, I have many device drivers that Agilent provided.
My question is: do I also need to purchase DAQ software that NI provides (i.e. NI-DAQmx)? I am unsure whether my materials are sufficient, or whether I need to purchase additional software. If so, please tell me why I would need that software.
Thank you,
Alex
(2,945 Views)
No, you only need to install DAQmx if you are planning to use a data acquisition board from NI. You would not have to purchase it in any case. It comes with LabVIEW and the latest version is available for download.
(2,931 Views)
Thanks for your answer.
Now you mentioned in another thread that instrument drivers usually come with an "Example" VI; however, mine does not have such a file.
This prompts me to still wonder how one goes about creating a program from dozens of unassorted VI files (instrument drivers). Are there tutorials or examples that demonstrate how this is done?
(2,918 Views)
There is some information at https://www.ni.com/en/support/downloads/instrument-drivers.html regarding how to develop a driver but a lot of what goes into creating an example or a full app, is just becoming familiar with the instrument itself and what all of the individual functions do. What I usually do is start with setting up an instrument manually to perform a specific function. When I have a driver, I then look through it to see what functions are there to duplicate that. Sometimes the function and control/indicator help is enough. Sometimes I have to look through the instrument programming manual and then search through the VIs to find the command I need.
(2,909 Views)
