This is my first data acquisition project. So I have a million
questions.
Some background first.
My task is to reverse engineer a hall effect sensor that is actuated
by some spinny stuff. I first must characterize how the sensor
behaves in situ. When I redesign this sensor, and the changes that I
make will cause some phase shift of the waveform, and changes in the
dwell of the waveform, from how it would have occurred on the original
part.
Consequently, I must be very certain of the phase shift and the dwell
of the original parts, and of the redesigned parts.
Specifically, I am interested in buffering signals. I am hesitant to
bring any signals straight into the computer which are not buffered,
even if they are the appropriate voltage. I just hate it when I let
the smoke out. Just to get my juices flowing I built a unity gain
follower. I used a 741 op amp. I input a 100 kHz sine wave. The
output of the op amp lagged the input by .18 microseconds. At the
speed which the mechanical system will run, this equates to a shift of
1/25th of.a degree. I want this shift to be less than 1/100th of a
degree, if possible. Or a lag of less than 45 ns.
I think this is reasonable, or at least that I really need it. I need
to know at what position, to the 10th of a degree, the sensors trip.
So I don't want to introduce any errors greater than a 10th of a 10th
of a degree.
So here are some of the questions that I have,
Is it ever appropriate to place unbuffered signals into the computer?
Should I make any distinction between the inputs to a counter card and
the inputs to a DAQ card, with respect to buffering or not?
If I buffer one signal but not another, how do I correct for the shift
in the one, to keep it synchronized with the other?
Do I need to qualify any buffers that I use and correct the timescale
in the VI? Or, must I use buffers which are all essentially the same
with respect to lag time?
Some of the signals will require attenuation, any recommendations
regarding fast, attenuating buffers?
I was reading some literature from a strain gauge manufacturer, they
recommended the use of an analog low pass filter. The idea is to
prevent aliasing of frequencies faster than the sampling rate of the
data acquisition cards. So they say pass only frequencies 1/2 or less
than the sampling rate. Is this reasonable in all cases?
Sorry to go on so, I have plenty more questions. The writing of posts
is sometimmes helpful in thinking a problem through. Hence, my
verbosity..
Mike
