Data from the same source appears differently when plotted in MatLab or LabView
Hi Mozglubov,
what is the status of this problem?
Ton
My LabVIEW Ideas
Message 21 of 22
(445 Views)
Sorry, I forgot I hadn't replied.  Thank you very much for your help.  I managed to use the program that was posted to convert the data that we had already taken from binary files to MatLab-friendly files.  It turns out the reason for the problem was that the leads of the array builder in the data capturing VI had been accidentally hooked up backwards, causing the data to be jumbled.  When I reversed the leads, the problem corrected itself, so now both the bin files and the dat files contain the same data.
Once again, I apologize for taking up your time and forgetting to inform you that the issue was resolved.  Thanks for checking back in.
Message 22 of 22
(430 Views)
