Data is not acquired because of an VISA error!!
@ Ravens Fan
Yes I clicked Refresh, it still did not show any thing. For I/O name filtering, I could not find it. I right clicked on the control on both block diagram and front panel, but didn't see it
Message 31 of 40
(1,014 Views)
@MoReese
I have a test bench or stand separetely. It is not a computer, it is a model of a hybrid engine with cooling valves and many sensors. I have to program my code to measure flow rate, pressure and temperature. The test bench is usually giving a valid resource name if I connect my original sub VI (Data_read), which I already attached previously, but not this main VI (Assembled VI). I tried to connect it to the test bench and clicked Refresh many times but it didn't show anything.
Message 32 of 40
(1,013 Views)
Can you take a screen capture of the issue you are having?  This might help.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 33 of 40
(1,005 Views)
Message 34 of 40
(999 Views)
Alright thank you for your helps. I think my vi worked in the way I want now. Thanks
Message 35 of 40
(988 Views)
Can you let us know what you did to fix it.  And please mark the appropriate solution.  Thanks.
Message 36 of 40
(985 Views)
I just tried to connect my vi to the test bench again and I saw the valid visa resource name.
It worked properly 🙂
Message 37 of 40
(982 Views)
So you don't know what happened?Smiley Frustrated  Well, at least it's working now.
Message 38 of 40
(974 Views)
36 post later....
This is why I was asking if English was not a good langauge.
Smiley Wink
Ben
Message 39 of 40
(959 Views)
Well i knew and understood everything you said though but i am quite new to labview so sometimes I couldn't imagine about what you told me. Thanks for helping 🙂
Message 40 of 40
(956 Views)
