Data logging failure...
Dear experts...
I am currently trying to collect acceleration sensor data using cRIO-9042 and NI9232 module, but when I run the FPGA code created by referring to the NI homepage, only the input data is 0... (please see the Figture)
If you know the cause or solution of this phenomenon, please reply.
I will attach a VI and a project.
Thank you.
Message 1 of 10
(5,596 Views)
I guess this is caused by error7. File path "c:\analog_input.tdms" is not valid for Linux-RT.
Please check valid path --> Working with File Paths on Real-Time Targets
GCentral
Message 2 of 10
(5,566 Views)
Dear, Emboar.
Thank you very much for your opinion.
I changed the file storage location to'/home/lvuser/test.tdms' by referring to the link you provided, but the same thing happens.
Maybe it's because of another problem.
Thank you.
Message 3 of 10
(5,537 Views)
Error 7 was removed? Or still there?
GCentral
Message 4 of 10
(5,526 Views)
Error 7 is gone, but the data is still only measured as zero...
 Thank you.
Message 5 of 10
(5,519 Views)
On FPGA VI,  there is type mismath. Mod2/AI0 is "signed, 24,7" but FPGA FIFO is "signed, 26,5".
Why don't you fix it.
When you directly see the returned FXP value on RT VI, do you also see "ZERO"?
GCentral
Message 6 of 10
(5,511 Views)
What sensor are you using?  Do you need to turn on the IEPE for the sensor?
Message 7 of 10
(5,466 Views)
Sorry, I'm late.
When I looked at the FPGA I/O output as a probe in FPGA.vi, I found the following values:
The meaning of the sentence in the red box is 'not executed'.
And Second figure is current Labview project tree.
What's the problem...??
Message 8 of 10
(5,397 Views)
Accepted by DNS_MTB
Notice in your project there is a I/O called "Mod2/Start".  You need to write a TRUE to this in order to enable the ADC on the module.  So write to that IO before your loop.
For more details: NI 9232 (FPGA Interface)
Message 9 of 10
(5,370 Views)
As you told me, I used 'Mod2/Start', 'Mod2/Stop'  block, then It works well !!
Thank you very much.
Have a nice day ^^
Message 10 of 10
(5,343 Views)
