Data logging through RS232 stops
Hi Ezzow,
@Ezzow wrote:
I'm not sure how to do that through LabVIEW. Is there any references you can suggest ?
You need to send a command before reading the measurement value - like you send any other command!
Hint: when you use VISARead to read some data you could use VISAWrite to send some data/commands…
Message 21 of 23
(411 Views)
I highly suggest you watch this video VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
Message 22 of 23
(390 Views)
Thank you RTSLVU for the tutorial link!
Message 23 of 23
(342 Views)
