Data not being read in in a waveform
When I read data in and display it to a graph it all reads in as one value. As seen in capture_code. I need the data to read in as a waveform. This code is running on my PC. When I run the code on a laptop it behaved the same but then after restarting it, it read in as a waveform. This is not happening with the PC. My colleague can have the same code running also and display a waveform. I am thinking it is some timing setting that I have overlooked. When I increase the timing delay in the for loop the data becomes a chunky square wave but increasing that delay affects the quality of the data.
Has anyone come across anything similar? Or know of any solutions?
Thanks.
(2,695 Views)
Hi there, are you running this code for a specific simulated device?
Would it be possible for you to upload your project & associated files in a .zip so that I can take a look?
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(2,624 Views)
I am reading geophone data in on a cRIO 9024 on module 9205. Ive attached the project with the VI.
Chris
(2,587 Views)
Thanks for sending this over,
Are you running the VI on WIndows or on the RT operating system?
It seems like this VI should be run on the cRIO controller and not on your Windows host.
You can change this by dragging the VI down to under the cRIO target within the Project Explorer.
Tim, CLD, CTD
(2,552 Views)
