Data sampling rate on waveform chart
Hi guys,
Im really new to labview 2019 and am trying to complete a project. The problem i am having is i cannot seem to adjust the rate that my analog channels plot onto my chart. What i am trying to achieve is a plot every 500ms but it seems to plot at about 3 second intervals. I have tried googling and adjusting just about everything but cannot get the sample time to change. i am using a cdaq-9178 and ni9208 analog card. If somebody could point me in the right direction it would be much appreiated as im feeling quite lost.
cheers
(3,804 Views)
Hi matdav,
LabVIEW2019 is also quite new and not widely used so far. You would be better by attaching a down-converted version of your VI. (I prefer LV2017.)
Open the "Voltage - Continuous Input" example VI. Set a sample rate of 2Hz and "Number of Samples" to 1. Then start the VI…
Generic suggestion: LabVIEW comes with a huge library of example VIs. Use them to explore features and learn about using VIs/functions…
(3,799 Views)
Thanks for the reply, I will try that suggestion now. I have attached a down-converted version as well.
Thank you
(3,792 Views)
Accepted by matdav_17
Hi matdav,
your VI is wrong in several things:
- you set the wrong sample rate
- there is no error handling after DAQmxTiming
- you don't start the task, but stop it…
- there is no loop in the VI: how do you want to repeat something "every 500ms"?
- the task is defined in MAX: we don't know your MAX settings…
Again: use the example VIs coming with LabVIEW and DAQmx!
(3,786 Views)
Looks like im way off! Looks like i need to do some more reading. Thank you for your reply and i will try your suggestions.
Cheers mate.
(3,784 Views)
